Help Needed!!! - Belmar/Lakewood, CO - Inspire 1 Pro
Is there anyone in the Belmar/Lakewood, CO area that can help an old man out?
I need some hands on help with an Inspire 1 Pro.
I just need need help fine tuning it
I'm in a hotel in Belmar/Lakewood, CO. I will be here for another two weeks.
I'll buy the beer, food, other....
I just want, need hands on help. I've read the manuals and still need help.
Thank you.
I am nowhere near you, but, what is the problem?
The Inspire has a bad drift to the right. It will not fly straight.
Also, when I let off the throttle, it stops hard. Almost goes vertical. No drift. Sudden stop.
The horizon is crooked in videos and pictures.
It's almost brand new in near mint condition. It's only been up in the air maybe 10 times at the most.
GPS works fine. Everything else seems to be okay as well.
Just need some help getting her tuned.
Thank you!!!!!
Sounds like a thrust imbalance which would come from a defective prop.
Try reversing the props to see if they are behind it. Put them on and fly a few seconds. Then switch the front for the rear of the red dotted ones. Fly again. Then switch the front / rear of the white dotted ones. Fly again. Any changes?
I would try an IMU calibration. Then a camera calibration. Then a compass calibration. One after the other.
That aggressive stop is because it's in gps mode. It will stop at the spot when you let go of stick inputs. If you want smooth stop, you'll have to use ATTI and pull back on the stick slowly to reduce speed u too complete stop. The GPS tries to stay where you give no inputs. So it does some aggressive stops.
Not sure if the inspire 1 can be calibrated to personal liking on the amount of pitch and roll degree angles, as far as I know.
mywifiext
