"How To Determine Which ESC Board or Motor is Causing an ESC Error Code and Not Start"
Thanks to all on why the ESC Error Code is showing when I try to start my V2.0 and creates a no start issue. How would I determine which motor and ESC board to replace?...Thanks to all.
The Assistant 2 software will allow you to fire the motors individually. I've not connected Assistant 2 to my Inspire, but I HAVE connected it to my P4P. And in the Phantom 1 days, the Assistant 1 software allowed me to test the individual motors. So...the message here is that if not the Assistant 2 software, DJI has SOMETHING that will allow you to fire the motors individually. That test should flush out the bad motor/esc.
Moved to Inspire 1 Help Section
@TITAN - why have you started another thread when you already have one running here......
Which one do you want to delete?
