Hello.! Could you give a little more detail about your problem? You say that when you install the camera in the I2, you have an image without problems, but when you rotate the camera 90 degrees (to the right or to the left) the problem occurs... does it occur when you rotate 90 degrees to both sides or only to one? ..The problem with the camera, is it when the original lens or 45mm lens is installed..?…I think you should reinstall the firmware of the camera and I2 and try again. Alternate between one lens and another to see if the problem persists, clean the connectors of both the camera and the I2 coupling, I don't think it's a problem with the camera's flex ribbon being damaged, if not, you would have a constant error or failure. Greetings.!I bought a X5s for the I2 and I did an update and the camera connects and everything works however as soon as I power up the camera flip 90 degrees. It basically goes vertically. What am I doing wrong? Had a I1 with the x5 had no trouble.
My apologies. So I have 2 cameras the X5s and the X4S. The X4S load it on the I2 and it goes through its progression and ready to fly. The x5s camera w/ 45 mm lens and fires up instead of going through the process of loading (spins & motor checks) it rotates on the axis 90 degrees. If you look at it from a quick glance it looks normal until u look at the screen the image that see through the screen 90 degrees except for the controls for drone operations is normal. No warnings says ready to fly. Look closely at the gimbal the camera is physically 90 degrees as well. Turn it on and it immediately does it. Wondering if one of the sensors are damaged. IdkI bought the camera used so probably get what u pay for.
I understand. You say that the camera is used, you do not have a history of the previous owner to know if the camera was with details.? When forcing the cam once it stops at the 90 degree position, it feels like the motor presents opposition when forcing it.? The camera being turned off has free movement when manipulating it..?. Perhaps the motors or the flex are having problems, perhaps it is best to send it to the DJI technical service. Luck.My apologies. So I have 2 cameras the X5s and the X4S. The X4S load it on the I2 and it goes through its progression and ready to fly. The x5s camera w/ 45 mm lens and fires up instead of going through the process of loading (spins & motor checks) it rotates on the axis 90 degrees. If you look at it from a quick glance it looks normal until u look at the screen the image that see through the screen 90 degrees except for the controls for drone operations is normal. No warnings says ready to fly. Look closely at the gimbal the camera is physically 90 degrees as well. Turn it on and it immediately does it. Wondering if one of the sensors are damaged. IdkI bought the camera used so probably get what u pay for.
