I2 landing gear servo need lube?
Hey guys, my I2 landing gear servo shaft has some white grease when it was new. These day those grease are running out. Any recommend for re-greasing?
A little white grease will do it no harm but it all depends the situations you flying in as if you In dusty environments then the crap will stick to the worm and actually is worse.
A smear of white lithium grease will do no harm but just a smear.
should we use lithium or silicone grease? both of them also common in RC model and mechanical lubricate
Hi, I found that a small amount of spray silicone on the worm gear works the best, this way you won't get dust sticking to it. I have used this on my previous Inspire 1, now use it on my Inspire 2.
Reactions: slim.slamma
