Inspire 1 Controller Functionality Change
Is there a way to change the landing gear controls over to a single button push on the remote? Raise/Lower with a single button function?
Not sure if anyone here has done this before..
Greg
Greg
Could you clarify what your inconvenience is?
You only need your gear down on take off and landing, and your landing gear can be set up for in menus to raise and lower itself based on closeness to the ground making it automatic, that is even easier than a button. and your manual option is one rotating lever for up or down on the controller?
If you mean going into transport mode it is easiest done from menu on the remote before you take your display screen off.
Kev
www.FlyingPhotos.ca
Understood, this was a project based on FPV and a single button push and release, I knew about the other options and was just curious if the remote was reprogrammable, thanks for the feedback
