Inspire 2 - 2nd slave remote not tilting/panning gimbal correctly (X7)
Hi friends,
I am able to control my gimbal with the master remote control wheels, but when my slave remote takes control, the gimbal only does very short burst tilts or pans, and sometimes barely moves (using remote sticks). Are there settings that might need changing. Everything is pretty much on Preset values out of the box. Sometimes it doesn't respond at all or just moves a few millimeters. ISO/Aperature,... control works fine, it's just the gimbal and focus.
Thanks for any insights
Inspire 2 Cinema Rig
X7 Camera DNG
Crystal Ski's
Hi friends,
X7 Camera DNG
Crystal Ski's
Hi I am having the same issue wit my inspire 1 pro. I wonder if it is a firmware issue ?.
When you were setting up the "Master" and "Slave" settings on your remotes, you should have seen a message pop up on the "Slave" controller, something like "request control permission from the Master controller?" ( Or similar)...
You should say yes..., then it will ask the Master for permission s , and the Master unit displays a confirmation message...
Did this happen? If you didn't do the "request permission", try changing the Slave back to the "Master" setting, then go through the process of changing it to Slave again, and it should bring up the question again, Request Control Permissions from the Master?"
I do not get the pop up windows for typing in password of the master . I get a message on the slave saying the current controler has gimbal control but it will not do what it is supposed to do , we will try your suggestions Thanks Chuck
It didn`t ask me for permissions either. I did film a video and uploaded it on youtube for you guys to see what it does exactly. The first remote is the slave. watch how its inconsistent also. The second remote is the Master on the finderwheels to demonstrate that the gimbal movement works fine in all axis on that controller.
SLAVE remote will not let me change the gimbal from the center mode thats highlighted on the picture to the first one where it points straight ahead. Does that have anything todo with it not panning correctly ?
25745
