Is there a way to set right control wheel for horizontal gimbal control.
Hi everyone.
I have finally gotten all the kinks worked out with my inspire, and have become very Comfortable with how the controller is layed out. I am making use of the left control wheel (next to record button) which I have modified the sensitivity of to do smooth vertical gimbal motions.
It seems odd to me that the right control wheel does not control the gimbal horizontally, and the only way I can do this to my knowledge is via long press on my tablet and 'pulling' the gimbal. This is obviously not great if I need gimbal movement in flight, as I only have two hands....
Is there a way to set the wheel to control the gimbal horizontally?
Thanks for any help!
No.
And given it has clicks it would be useless, which is precisely why you can't.
You can switch the left wheel between pitch and yaw though... or just fly in follow mode and yaw the aircraft.
No.
Yawing with the craft is not reliable enough (or I am not skilled enough) to get consistent, smooth movements. Did not know it was possible to change left wheel to Yawing though. Thanks, it's a start.
