Issue with the battery? [Cell Broken]
Hello.
I went through the battery history today just to check things, and i discovered on one of my batteries it says
Overcurrent in Discharge
Over Temperature in Discharge
Low Temperature in Discharge
Short Circuit in Discharge
Cell undervoltage protection due to overdischarge
Cell Broken
Time to Discharge.
It doesn't say the same message on all records, but some of them. Anybody got any idea what can be the problem? I've always charged them to 100%, and usually land before it hit the 30% mark. The other two batteries had no issues.
I haven't experienced any problems during flight..yet
Is this on the tb47 battery? I'm like you I alway land about 30% but I'm currently landing at around 50% and doing the battery breakin process. I think mine disappeared after this latest firmware update. Just check all the cells, if they are all within .1 of a volt you should be fine, but keep an eye on them when you are flying should mine are within .2 of a volt when loaded.
yes, this is the TB47. gonna do some small testflights and see if it goes back to normal.
Just don't want to crash mid air .. But everything else looks fine (as you can see on the second image)
ziamedicalcenter
