lens hood for Olympus 12mm f2
Has anyone found a decent lens hood for the 12mm that you can use with a polarizer or other filters? The only one I have found is the official Olympus square metal hook=d, however you can't slip it on over the polarizer. You can install the polarizer after the lens hood is on, but it's nearly impossible to get it on and then equally difficult to remove since you can't get a grip on the filter only the polarizing adjustment ring.
Thx...Jim Watt
LavernePre
