My first edit from Farm / Check it :)
I like it and only noticed a couple of things. At about 30 sec in there is a moment you can see your props in the upper frame. In lining up your shots you make several running away from the sun and you have a flare drone shadow artifact that can be seen. I would apply movement smoothing over the entire piece. I would also consider jacking around with the color palette and giving it more pop.
Reactions: slim.slamma
MEH, this video is not available in Germany due to collecting mafia-society issues.. :mad:
Udaipurescort66
