New pilot need some quick help
1. I can seem to get the newest firmware update to update to I1. It still shows 1.2. Xxx. I downloaded the zip file, extracted it then put the file on and empty Micro SD card. Installed card in camera and turned I1 on. No update
2. My second controller works but I think the USB slot slot is bad as I can't update the controller.
3. The plastic mount that mounts to the raising lowering gear is broken on one side. Do I have to replace the hole tube?
4. T48 battery is saying "broken cell" #1 cell is significantly lower then the others. Battery only has 3 charges. The history shows ok, ok .. then self discharge in storage...
Any help will be appreciated
Sent from my SM-G920V using Tapatalk
stellaralloys
