newbie question for thermal camera interface
Hello,
I have a device that requires GPS coordinates:
https://www.infraredcamerasinc.com/...sensor-control-module-interface-options-1.pdf
The device was designed to accept GPS data via canbus from the A2 controller. On the M100 I can see 2 available canbus ports:
- Can Hub on the GPS module, and
- GPS Can port (reserved).
Can anyone suggest if either of these ports can supply GPS data?
Also, the device should be able to accept camera triggering via TTL/PWM (see link above). Any idea on where this signal may be coming from?
Any input is greatly appreciated.
Thank you,
Mark
