no video
Everything works fine, however no video - says disconnected. This first happened just prior to the latest firmware update and became a constant no video after the update.. Also, this is weird, after the update I no longer have 1080 25p as an option.
You might have bent the pins on the gimbal? I pulled off the lens cap the wrong way once and did this, thought I'd have to send it to DJI but was able to bend them back with a paper clip and they've been fine since then.
I am having the same issue. I touched the cables on the left side and they connect giving me video for a second then off again to disconnected...
All pins look good. Just had a flight and it worked. Let's see in an hour! Thanks for your response
aditisharma011
