OsmoPro - does the x5 fit in the inspire
hello there,
If I buy the Osmo Pro (which comes with the X5) can I then, buying the X5 plate, install the X5 that comes with that Osmo in my Inspire and use the X3 on the osmo?
Correct, you would have to buy the X5 Plate ($100). You would also need to remove the X5 adapter off the Osmo but then your X3 should work fine on the Osmo.
Reactions: Goncalo Proenca
