Possible Gimbal damage
Vermont
www.video-vermont.com
When the Inspire Pro X5 is set up with the default equipment,,, i.e. 15mm lens, ND filter and lens hood, should the gimbal balance perfectly in static mode that is without power? I own other camera gimbals and they also require static balance.
I am pretty sure that it should. Mine is dropping down to the left. This follows a crash in which the craft landed on its back.
I am not experiencing any problems when flying and taking video. I have flown missions with Litchi and POIs with the Go Pro App. Everything appears okay. The video is still rock steady. No vibrations visible.
If I suspect damage is it worth sending it somewhere for inspection and repair, under these circumstances, if so where?
Billchris7
