Problem with new Firmware Update
I just updated my Inspire 1 with the new firmware. The aircraft and controller both showed that the update was a success, but when I turned it on to go fly, it would not connect. When I checked the status, it stated that I needed to update the firmware on both the aircraft and controller. What the heck can I do to fix the problem?
It sounds like you upgraded the aircraft, but the upgrade did not happen to the controller. Delete all the files on your SD, except the .bin file, and try it again. Once both are upgraded, they will connect fine. Same thing happened to me.
