Processing DJI Drone DNG using Perfectly Clear as a plug-in
Portland, OR
www.portlandprodrones.com
This is an article I wrote for Photofocus.com. I hope this is helpful.
In this article, I’m going to show you how you can process your DJI Drone DNG RAW Photographs using Perfectly Clear 3.5. Since Perfectly Clear doesn’t yet support the DJI Drone cameras, you will need to launch Perfectly Clear as a plugin from inside editing software that supports the Perfectly Clear plugin. I’m going to show you how to do that with Lightroom, Photoshop and Capture One Pro. For these methods to work you will want to have installed Perfectly Clear on your computer. For more information about how to use Perfectly Clear, check out Photofocus.com for tutorials.
You'll find the full article here:
Processing DJI Drone DNG using Perfectly Clear as a plug-in | Photofocus
ziamedicalcenter
