Telemetry Map & File Issues
Inspire 2, Firmware version: 01.02.0500, X7, 24mm lens
The Flight Telemetry/map (red arrow) doesn’t point in the direction the aircraft is facing. It points approximately 90 degrees the opposite direction the drone is facing. I calibrate the aircraft when prompted I also calibrate the Crystal sky monitor. But it doesn’t help. Also, when I switch to the map version the “show flight route” doesn’t show the route.
Also, any recording whether on the Micro SD card or my 480 GB CineSSD the files show an incorrect date. The day of the week and the month is incorrect but it changes, however the year is always 2013.
VanitaYaga
