Terrible video transmission
Can anyone explain why the video transmission is so terrible on the I2 with x5s? It's not 1080p and definitely not 720p quality. Am i doing some wrong? Using iPad Pro.
My guess is that your iPad Pro resolution is to high and the video transmission is being upscaled tremendously. Plus check your tramsnmission quality. You will only get 10mbps if you are relatively close to the drone and will drop off to about 6-8 mbps the further away.
My recommendation is to get a boosted system to improve penetration and video transmission.
I found a solution to this it has to do with the I2 when you use AUTO vs. CUSTOM in the transmission settings.
You will have your best luck with Custom... AUTO seems to bounce channels a lot and thus disrupts the feeds.
Mavic is the only platform i've used that has a good auto system BUT it is also Occusync not light bridge so... that may be it.
