The power of perseverance :)
I was given a DJI 15mm lens a while ago, which, together with it's X5 camera had been for a little trip in the sea.
Predictably, trying the lens on my Olympus PEN EPM1 test mule didn't do much - just a black screen on the display, but at least it didn't complain about the lens (I have a smashed Olympus 12mm which the camera does NOT like at all)
Given the lens is essentially a Panasonic 15mm ASPH lens (maybe without the Leica optics), I contacted the UK repair centre for Panasonic. Unfortunately they're take was that being DJI-branded, there were no servicable parts inside and that a salt-water dunking would be terminal anyway.
I was curious to see inside it and there was nothing to lose so I dissected as much as I could, taking photos along the way so I could get it back together again. The rear lens element was cleaned and I brushed clean all of the electronics with 99.9% isopropanol, then popped it back on the camera.
Surprisingly I now got an image onscreen! None of the focusing worked and the dirty central lens made for a really murky shot but it was progress of a sort.
It got me to thinking - for drone work, if I could set the aperture wide open and the focus to infinity, it'd work pretty well. Certainly better than scrapping it.
I had another go at disassembling it and after a lot of head scratching (and using much more force than was comfortable) I managed to disassemble the front of the lens too. This provided the necessary access to the focusing lens and diaphragm so I was able to clean the rest of the lenses and gave the motors an isopropanol bath.
It all went back together again and back on the camera to see whether i could now get a clear image. Not only was the image nice and clear, the autofocusing had popped back into life.
All in all a better result than I could possibly have hoped for.A methodical approach, some perseverance and a healthy dollop of luck can get you a long way!
I was curious to see inside it and there was nothing to lose so I dissected as much as I could, taking photos along the way so I could get it back together again. The rear lens element was cleaned and I brushed clean all of the electronics with 99% acetone, then popped it back on the camera.
I had another go at disassembling it and after a lot of head scratching (and using much more force than was comfortable) I managed to disassemble the front of the lens too. This provided the necessary access to the focusing lens and diaphragm so I was able to clean the rest of the lenses and gave the motors and acetone bath.
Good news.......for now but don't be too surprised if the salt water gets you in the end. :(
Salt water corrosion starts from the second it gets a dunking and on electronic/optics doesn't really ever stop.
I admire your perseverance but time will tell if it is still serviceable after a few months......
Good luck.
Thanks Ed., it's a good point you make. Truthfully, I'm not expecting it to last but I'll keep my fingers crossed :)
