Unscheduled landing
South Florida
So i've been flying near my home all weekend, properly calibrated IMU, freshly charged battery, Fl 375 AGL, 11 mph winds in the air for about 5:00 and.....
Any suggestions before sending it off to DJI for analysis?
btw I had the Olympus 14-42 lens attached.
After you do that you can share your logs from the healthy drone page and someone here smarter than me can see if they see any thing that may have attributed to your unscheduled landing (crash) sorry for your loss.
Did you check if you unintentionally enabled the csc function? You can do that in the go app itself.
Reactions: SanCap
No, I am viewing the log now and watching stick inputI was at 21% forward thrust when the craft lost control at 380 ft AGL. i could hear the motors running and it appeared to correct itself as it spiraled down numerous warnings "Warning Gimbal Roll reached end Position" appeared. I going to watch the video if I can figure how I will upload it here. I am less concerned about the loss of the craft as to what occurred, I thank each of you for your input, SanCap many here claim to have the intellect but you are willing to share yours, Thank you sir!
The healthy drones logs will help more than the video.
Mine don't either. I click on the blank space, and then the files show up for the app in the right pane. (iTunes bug)
Is anything showing on the tips and warnings button on the right under the overview tab?
Flight timeAltitudeHome DistanceTypeNotificationA00m 00s0.0 ft0 ftModeMode changed to GPS_AttiB00m 02s0.0 ft0 ftModeMode changed to AssitedTakeoffC00m 02s0.0 ft0 ftTipTips__RC Assisted TakeoffD00m 22s0.0 ft2 ftModeMode changed to GPS_AttiE00m 24s4.6 ft3 ftTipLanding gear raisingF00m 30s8.2 ft8 ftTipLanding gear raisedG02m 13s372.4 ft35 ftWarningWarning:Maximum flight altitude reached. Adjust in MC Settings if necessaryH04m 57s374.3 ft589 ftWarningWarning:propulsions output is limited to ensure the safety of the battery.I05m 19s369.4 ft129 ftWarningGimbal Roll reached the end positionJ05m 20s332.3 ft119 ftWarningGimbal Roll reached the end positionK05m 22s308.4 ft117 ftWarningGimbal Roll reached the end positionL05m 22s294.3 ft117 ftWarningGimbal Roll reached the end positionM05m 23s286.1 ft116 ftWarningGimbal Roll reached the end positionN05m 24s268.0 ft118 ftWarningGimbal Roll reached the end positionO05m 25s248.7 ft114 ftWarningGimbal Roll reached the end positionP05m 26s226.7 ft115 ftWarningGimbal Roll reached the end positionQ05m 27s205.4 ft107 ftWarningGimbal Roll reached the end positionR05m 28s182.1 ft107 ftWarningGimbal Roll reached the end positionS05m 29s161.1 ft99 ftWarningGimbal Roll reached the end positionT05m 30s130.6 ft103 ftWarningGimbal Roll reached the end positionU05m 31s114.2 ft100 ftWarningGimbal Roll reached the end position
This looks like the the motor output was decreased, and then could not hold the craft in the air?
ChristiFar
