Using TB48 with other drones....
I just wanted to to do a gut check, I want to make a connection harness to use (2) TB 48s in parallel, w/ my DJI S800 EVO, and can't think of any reason why they won't work well...
Other than the fact that they will be a little on the lower end of the mah range (11,600mah) is there anything I'm missing?
An educated guess will be that you will miss out on the telemetry data that is sourced via the small pin connections. Assuming you're using a DJI charger (which will automatically balance charge), I see no reason why those batteries can't be used for just about anything you want. Power is power. They are very robust batteries.
ringquiet
