what about 17.5hp total 6 uav engine pulling ?
Classification and characteristics of plant protection uav
Plant protection uav is divided into multi-rotor plant protection uav, co-axial helicopter and single-rotor plant protection uav. According to the mode of power hybrid model, it can be divided into: electric multi-rotor plant protection uav, oil moving multi-rotor plant protection uav, oil electric hybrid multi-rotor plant protection uav, oil moving variable pitch plant protection uav.Generally, coaxial plant protection helicopters are only oil-operated ones, which have not been used in the actual plant protection operation.Electric single-rotor plant protection uav, oil moving single-rotor plant protection uav, etc.The multi-rotor implant-protected uav can be divided into four rotors, six rotors, six rotors, eight rotors and eight rotors.Single-rotor implant-protected uav has two OARS and three OARS.Eppo drones and other tasks system of unmanned aerial vehicle (uav) the biggest difference lies in the eppo unmanned aerial vehicle (uav) belongs to the low speed machine, usually the highest speed of no more than 13 m/SEC (speed of no more than 47 km/h), and other tasks system of unmanned aerial vehicle (uav) generally can reach 100 km/h top speed, maximum speed even up to 160-200 km/h ,gasoline uav engines can maximum speed even up to 350-400 km/h.
In the flight of multi-rotor implant-protected uav, forward, backward, horizontal, steering, elevation and reduction are mainly carried out by adjusting the rotating speed of the blade. The characteristic is that the two adjacent blades rotate in opposite directions.Easy to learn, a short time can learn homework, rotor eppo automation degree of unmanned aerial vehicle (uav) ahead of the other models, a model aircraft based on basic will their assembly, for other type of the load, the lower cost compared to the same load cost is lower, more than 20 kg models compared with the single rotor eppo unmanned aerial vehicle (uav) has been basically no cost advantages, cost and energy consumption of unit rotor eppo drones to two-thirds or more higher than single rotor eppo drones, efficacy than the lower.Most of them are more suitable for field operation except the current oil moving multi-rotor plant protection uav.
