What are MOD values?
Hi, i keep seeing posts with comments about MOD values, could anyone explain them and how to check them... please keep it simple, I'm no tech head!
cheers
cheers
OK, without going into the 'Techy' side of things they are basically sensor bias off set values.
What you are looking for is (at rest with the aircraft on the ground):
Gyro : 0.00
Accelerometer: 0.99-1.02
Compass: 1400-1600 (can be slightly outside that range without problems but the value will fluctuate)
These value fields can be found on the sensors page in the app.
thank you for this info, if you feel like going a bit deeper on the tech side, please do.
many thanks
cozyandcas
