Where is CinemaDNG/ProRes License?
Ok, so this might be an immensely dumb question but I'm brand new to Inspire 2. Haven't even turned it on yet. My question is: Where is my CinemaDNG/ProRes license? Is it a code I have to input somewhere or is it just built into the Inspire 2 and the options will show up on my controller? There is a CinemaDNG/ProRes sticker on the side of the drone. Thanks.
The sticker on the main controller does indicate that it had its licenses pre-loaded to the CineCore (image processor) at the factory. To see that the licenses are on there you can connect the bird to Assistant 2 (download from here if you have not already done so) and then go to the "License" section. See the screenshot below showing a CinemaDNG license loaded on an aircraft as indicated by Assistant 2.
Appreciate your response. But that would actually require me to activate the drone..haha. Which I've been holding off on for no real good reason. I was hoping to verify this before turning it on so if something was hinky I could return it. Also, I want to get Care for it and the camera before activating it which is hella expensive. Thanks.
Reactions: Advexure
