Won't Get into Travel Mode only Powering On instead
atortphotography.com
Not sure why when depressing the button 5 times or whatever it is to get it to go into travel mode it is only powering on now. I never had this happen before any idea? Thanks.
Burned out servo, or stuck worm drive screw.
Put a smallish flat blade in the hole in the belly and lower it manually then test again.
