- Joined
- May 15, 2019
- Messages
- 3
- Reaction score
- 1
- Age
- 72
do you check the firmware both(RC and AIRCRAFT9Recently my x5s camera disconnects mid flight and after a couple of minutes reconnects. Has anyone else had Thi problem?
Yes the Firmware is up to date.. Could be the contacts to the camera. Tried to clean them. It only happens intermittently though.do you check the firmware both(RC and AIRCRAFT9
It could be that the GO4 crashed which is quite common, unfortunatelly. Did you get any message on the screen?Recently my x5s camera disconnects mid flight and after a couple of minutes reconnects. Has anyone else had Thi problem?
Cleaning the strip contacts on the antivib plate as well as on the gimbal is the only thing I can think of. I use cotton but and squash the end with pliers so it fits nicely in the strip contact slot on the gimbal end before dipping it in alcohol (IPA) and then another run with dry end.No I didnt get any message and the FPV camera image was still there, It was just the main camera image that disappeared'
I have had this problem a lot. Finally a couple of months ago I realized that my proximity to power lines will affect my image transmission at times. The last few times I have lost the image transmission I walk around and relocate where I am controlling from and the signal reconnects. This has been my experience, certainly not saying it is the blanket fix. You might give it a try.Recently my x5s camera disconnects mid flight and after a couple of minutes reconnects. Has anyone else had Thi problem?
