Z30 camera not working with Matrice 100
I'm attempting to get my newly acquired M100 to work with my known quantity Zenmuse 30 camera. This Matrice was doing the constant Beep Beep Beeping, and I used my old X-3 camera to reinstall firmware version 01.09.01.40 and this stopped the racket, and it restarted and shows telemetry now. I then installed the Z30 style gimbal, but the camera just hangs there and has no feed or movement. What to do next please?
Im going to assume this issue was solved. However if not , Check settings, firmware, etc. again, if Z30 is working your missing something. Can you post screenshots of your issue?
Thanks, there turned out to be several modifications made to this drone's firmware, causing a crash (no camera attached at that time.) I since replaced it with a M100 from the Mythbusters inventory. It had only been flown 4 times. Now adding guidance to it, cameras to come. Thanks for your interest.
VanitaYaga
