1345T Propeller locked on - any ideas?
As the title suggests, after flight today I tried to remove one of the propellers (1345T) and the quick release lock simply won't undo. All were installed correctly and I did nothing different to the other three that I managed to fit, and remove, with no issues.
Anyone experienced this before? Thanks.
How did you make out with that ?
So was it a problem with the clip that gets screwed on to the motor ? Or the twist lock itself ?
The twist lock wouldn't un-twist. Whether a small amount of grit or something was caught between the clip and prop when it was done up but it was not coming undone with the fingers!!
JayneMiche
