AirData ?
RBP
Do many of you use AirData for recording your flights? I just sent them a note asking if they would add the second battery to their reports for the Inspire 2. I know the Inspire outputs that data but their software should be able to display it. Maybe if enough Inspire 2 folks requested it they would update their software.
Reactions: Phil DeVore
I’ve got a Inspire 2 with 10 batteries and all of them show up on my Airdata flight logs. Do you download your flight records after every single flight and then sync that info with your Airdata app? If you don’t then they won’t be there.
Interesting, I must be doing something wrong. I don't use DJI go very often most of my flights are Litchi and Drone Deploy. What I'm referring to is the CSV files.
There’s some tutorials on AirData on YouTube that can walk you through it all.
Reactions: RBP
I received a response from AirData, they do not support the second battery.
oharac
