It was allready on the Android version,don't know about IOS,but my guess it was there before.Well, I’m still having some delay and lag issues BUT one feature I find really cool is that now pitch,yaw , AND roll can be used at the same time by your finger on the screen! I’ve been using IOS since all the problems with Android so I don’t know for sure if it was there before but I never noticed it.
That gives the ability to have someone control the camera and someone to fly WITHOUT using 2 controllers! Seems like it would make for a much more smooth shot since the camera will pan in a much more fluid direction
I'll have to check the IOS. Not sure if it's something I have to enable with the iPad? I've only had my I1 for 2 weeks so I'm still learning BUT it's a cool feature for a single TX user!It was allready on the Android version,don't know about IOS,but my guess it was there before.
Yup - it's been on both platforms since February.It was allready on the Android version,don't know about IOS,but my guess it was there before.
You probably mean connection to the RC through the USB cable. The connection to the drone itself is handled by the RC. Make sure you turn USB debugging ON to your tablet, otherwise you won't be able to connect.Well, I upgraded my newly replaced Nvidia Shield 16Gb tablet to DJI GO and cannot make a connection to my Inspire anymore. Have tried switching USB mode between MTP and PTP but no luck. It just won't connect. Running Android 5.1.1 . Now going to try to upgrade the Inspire to the new firmware and then try again.
After upgrading all is working ok again!Well, I upgraded my newly replaced Nvidia Shield 16Gb tablet to DJI GO and cannot make a connection to my Inspire anymore. Have tried switching USB mode between MTP and PTP but no luck. It just won't connect. Running Android 5.1.1 . Now going to try to upgrade the Inspire to the new firmware and then try again.
AndreasFor those not wishing to upgrade yet, make sure you turn DJI Pilot app auto update to off. However, if you did get the updated DJI GO by accident, as it happened to me, there is no clash with the old FW 1.2.06. I flew over the mountains, no lags, stable as a rock.
Note that google play-services updates are turned off, using the native versions of Android 5.0.2 on a Samsung Galaxy Tab S 8.4 (for reference, Google Play Services version should be 6.7.77)
I'll proceed with the 1.3 and see what happens.
@Walksalot, go to Settings > Applications and find Google Play Services. Click to enter the app settings and press the button Uninstall Updates. Follow what it says and assuming you have Lollipop installed (Android 5.0.2) you'll end up having the native version of the app: 6.7.77Andreas
How do I get back to 6.7.77
