AutoPilot Multiple Flight Plans in Flight
Hi all, hope you are well.
I may have a stupid question regarding Autopilot app and Inspire 1 v2
Is it possible to load a new flight plan whilst inflight after another plan has completed?
Example:
A) Fly to pre-planed POI using target mode and hover,
B) Load new Orbit flight plan in-app and orbit a second pre-planed POI nearby.
If this above is possible is it wishful thinking to combine target / waypoint modes with a orbit in a single autonomous mission?
Thanks in advance.
Example:
Thanks in advance.
If I understand your question correctly while you're flying in mission you want to be able to after the mission is complete while the bird is still hovering to load a new mission. If that is your question the answer is yes you can. I do it all the time
Example:
Thanks in advance.
if I'm understanding your question correctly you're saying after your mission is complete in the bird is still in the air you want to lay out a new mission and then start that mission. The answer would be yes I do it all the time. Let me know if I can help you in any other way I use the Autopilot app quite often and really like it talk to you soon
AllieFarne
