- Joined
- Oct 12, 2016
- Messages
- 1,090
- Reaction score
- 569
has anyone else tried this...? I'm sure I read or saw somewhere that the batteries could be hot-swapped to speed things up. However, I've not been able to find the reference again, so may have mis-read something!
Anyway, My second battery pair arrived today, so after their first flight, I thought I'd try out the hot-swap feature....
With the aircraft landed, but still powered up, I ejected one of the batteries, replaced it with a full one, then did the same with the second one. Easy to do on the outer button ring, I fumbled the button on the inner ring on the second one and managed to eject both. Hmm, ok, maybe not so simple. Tried again after the second flight finished, replacing the batteries with the first set. This time I used a blunt stick to depress the inner button first, popped the battery out, fresh one back in, outer button pressed, battery out and next one in... yay It worked and the aircraft stayed powered up .
But... the status line in the top left of DJI Go was complaining about a battery fault and mismatched something or another... so powered down as there wasn't enough in the batteries for flying anyway. Also, I forgot to note the exact wording I guess ithe system got itself tangled with battery serials/pairs etc and that hot swap isn't a real feature .
Anyone else heard of the feature and tried it? And did you have any success?
