Best Data Acquisition App for Android?
I recently picked up a couple of the crystal sky displays and am now experimenting with pix4d capture.
So far it seems easy enough. I like the options for flight planning for the most part, however there doesn't appear to be any way to adjust for elevation changes in your survey area (luckily I'm in FL where its flat).
I've run it through small missions, multi-flight missions, and aborted mid-mission all with successful RTH and also switched into ATTI-mode and piloted home without a problem so it seems to be functioning properly from a safety standpoint.
I am however very curious as to what others have found with the app or what they are using for data acquisition with android.
What app are you running? How do you like it? Anything else I should know about pix4d capture?
