Can't attach x5S to I2
SEI
I can't figure out what I'm doing wrong. I line up the red with white dots but it just won't lock in place? Has anyone else dealt with this?
Thank you
Thank you
Tip the front of the Inspire up and look at the contact that connects with the camera/gimbal contacts. Sometimes the contacts on the X5S mount will turn slightly of center preventing the X5S from mating properly. If that is the issue you can depress the lock button on back of the camera and rotate the contacts to match the gimbal.
Welcome to Inspire Pilots!
Thank you, when lining up the white with the red it doesn't match at all. I'm unable to find an unlock button which would allow me to move either the gimbal connector or the gimbal itself.
Thanks again, I'll keep looking
That worked, thank you. I didn't know the connection could move! Not much in the manual on that!
Thanks again,
Nice cold Sunday for these heated batteries! Happy flying :)
VanitaYaga
