Controller connection issue.
Recently I found Inspire 1 v1 for sale at $190 CAD, hard to pass and just went for it. Seller have informed that controller is not connecting to drone and I was thinking it's just simple binding issue. So I got it and did binding process. Press c1, c2, and rec button same time and press camera setting button to put into binding. controller was flashing blue indicating it was in binding mode. I turned drone on and it was in yellow flashing and I pressed binding button on it. And.... it's not binding kind of. So drone it flashing yellow light but controller, when drone is not on, it's solid red led and when drone is on, it's cycling red, green, and yellow fast. I tried to connect to dji go app to dig in more and it wasn't showing up in the app. I connected iphone 15 pro max using usb a to usb c cable which is working fine to connect to pc and transfer data. It was just showing how to connect button on it. I'm not sure what would be next step I would do. should I go get another controller and see if it work?
CodyF
