D-Log compatibility with I2
Anyone know if DJI has updated the DLOG option? Last i checked, it was removed. Client wants DLOG on shoot but if it's not there, I'm wondering if Cinelike might suffice.
It is there, hidden behind the undocumented "EI Mode".
Enable EI Mode, then you will see. D-Log option.
Then you can set "SD/Liveview Looks" to "Rec.709" to get a corrected view/histogram/waveform.
Almost completely undocumented.
Reactions: ajgrattan
Ok thanks
This only works if you have an SSD? I didn’t think EI mode works if your only using h264 and a micro USB
Yup, I was flying yesterday without the SSD installed and "EI Mode" was not available. Only D-Log for H.264 and H.265.
