- Joined
- Jan 16, 2021
- Messages
- 95
- Reaction score
- 31
- Age
- 50
First off, I want to start by making some observations in regards to the upgrades/downgrades. It would seem as if DJI *REALLY* doesn't want anyone downreving from v01.11.01.50. But, I do believe there is some confusion in regards to how they do it. I do NOT think the hardware in the drone itself has any ability to "lockup"/"freeze"/"brick" in any *real* sense. It is a controller with system modules and will do it's thing.
What I do think is they have engineered things to use the cameras as the "fault" point in doing upgrades/downgrades. If cameras are at certain revisions, I do believe the order in which they do the updates to the the various systems (which include the camera) ends up causing the "issues" people have, including bricking cameras and the Inspire craft itself.
They know the camera is the interface to the MicroSD card. If you screw with that you can prevent downgrades. Change the order of the downgrade and if you try going from say v01.11.01.50 to v01.08.01.00 you will create chaos because they have made multiple revisions to the camera system in the interim firmware updates. They elude to this in their release notes for various cameras by stipulating that with certain revisions you can only go back to certain other revisions (ie, safe revisions to downgrade to). Funny part is that v01.11.01.50 does not have any notes like this, thus they never intend a downgrade once installed at that revision.
I have found a "hack" to get around bricking my own cameras. I have a X3, Z3 and X5. I *DID* brick the X5, but it was a "half-brick" in that the camera starts but doesn't communicate with the aircraft (this happened well before I did more investigating early on). Now I was not willing to sacrifice my other cameras (X3, Z3) so I went the next step and used a FC350Z camera from my Osmo+. Since it identifies as a FC350Z the FC350Z firmware will load with it, but since they hamstrung that camera so the gimbal will not work with the Inspire 1 I figured it would not allow the same "fault" to happen that bricks others X3 and X5 cameras. Now, this assumption might be totally wrong and it might be the fact that it is the Z3 (FC350Z) and they are "immune" to the "fault" that they use to make downgrades difficult, but in any case, I am just letting everyone know what *I* know works.
The rest here will look at the firmwares themselves and try to determine exactly where the radio module changed to cause all the issues in range after the v01.10.01.40 firmware.
Another note is the earliest firmware for the Z3 is the v01.09.01.30 firmware. The next is v01.09.01.40 and then you jump to v01.10.01.40 which is where all the problems start. The only last revision for the Z3 is the v01.11.01.50 that is the latest for all cameras. So the z3 has only had 4 firmwares posted for it that I can find anywhere.
Can we "assume" that major system changes (radio, camera) or flight parameter systems (NFZ, height) changes would cause major firmware revisions (v01.10.x.x vs v01.09.x.x)???
Below is a listing of the various firmwares and the module revisions per the log using a Z3 camera for updates on a Inspire 1v1.
v01.11.0150 v01.10.0140 v01.09.0140 v01.09.0130 System
[01 00][00] v2.77.5657 -> v2.73.5514 -> v2.73.5514 -> v0.1.5346 Video Processing Loader ----------
[01 01][00] v2.77.5657 -> v2.73.5514 -> v2.73.5514 -> v0.1.5346 Video Processing App ----------
[01 04][00] v1.11.5658 -> v1.8.5460 -> v1.8.5460 -> v1.7.5327 Camera BCPU ----------
[03 05][00] v34.1.0.5 -> v34.1.0.5 -> v34.1.0.5 -> v34.1.0.5 Flight Controller Loader
[03 06][00] v2.4.20.50 -> v2.4.20.50 -> v2.4.20.18 -> v2.4.20.18 Flight Controller App **********
[04 00][00] v1.31.1.83 -> v1.30.1.47 -> v1.30.1.47 -> v1.30.1.21 Gimbal Master ----------
[04 01][00] v1.4.26.18 -> v1.4.23.18 -> v1.4.23.18 -> v1.4.15.18 Gimbal Module ----------
[04 02][00] v1.4.26.18 -> v1.4.23.18 -> v1.4.23.18 -> v1.4.15.18 Gimbal Module ----------
[04 03][00] v1.4.26.18 -> v1.4.23.18 -> v1.4.23.18 -> v1.4.15.18 Gimbal Module ----------
[05 00][00] v3.0.6.2 -> v3.0.6.2 -> v3.0.6.2 -> v3.0.6.2 Central Board
[09 00][00] v5.0.0.0 -> v5.0.0.0 -> v3.0.0.4 -> v3.0.0.4 Lightbridge Comms **********
[11 00][00] v3.10.0.0 -> v3.9.0.0 -> v3.9.0.0 -> v3.9.0.0 Battery Module
[12 00][00] v1.11.0.0 -> v1.11.0.0 -> v1.11.0.0 -> v1.11.0.0 ESC Module
[12 01][00] v1.11.0.0 -> v1.11.0.0 -> v1.11.0.0 -> v1.11.0.0 ESC Module
[12 02][00] v1.11.0.0 -> v1.11.0.0 -> v1.11.0.0 -> v1.11.0.0 ESC Module
[12 03][00] v1.11.0.0 -> v1.11.0.0 -> v1.11.0.0 -> v1.11.0.0 ESC Module
[17 00][00] v1.1.0.8 -> v1.1.0.8 -> v1.1.0.8 -> v1.1.0.8 VPS Camera Module
[17 01][00] v2.0.1.6 -> v2.0.1.6 -> v2.0.1.6 -> v2.0.1.6 VPS Sonar Module
---- Uprev in module from firmware to firmware
**** Different from v01.09.x.x to v01.10.x.x
This is a refresh on Inspire 1 V2 w/01.11.01.50
[04 00][00] v1.31.1.77 -> v1.31.1.67 Gimbal Master ======== (no [04 01/02/03])
[08 00][00] v2.14.9.42 -> v2.14.9.42 FPV Feed ++++++++
[01 00][00] v1.22.5037 -> v1.29.5379 Video Processing Loader ========
[01 01][00] v1.22.5037 -> v1.29.5379 Video Processing App ========
[01 04][00] v0.2.4270 -> v0.5.5085 Camera BCPU ========
[03 05][00] v34.1.0.5 -> v34.1.0.5 Flight Controller Loader
[03 06][00] v2.4.20.50 -> v2.4.20.50 Flight Controller App
[05 00][00] v3.0.6.2 -> v3.0.6.2 Central Board
[09 00][00] v5.0.0.0 -> v5.0.0.0 Lightbridge Comms
[11 00][00] v3.9.0.0 -> v3.9.0.0 Battery Module
[12 00][00] v1.11.0.0 -> v1.11.0.0 ESC Module
[12 01][00] v1.11.0.0 -> v1.11.0.0 ESC Module
[12 02][00] v1.11.0.0 -> v1.11.0.0 ESC Module
[12 03][00] v1.11.0.0 -> v1.11.0.0 ESC Module
[15 00][00] v1.1.2.0 -> v1.1.2.0 USB Controller (Camera) ++++++++
[17 00][00] v1.1.0.8 -> v1.1.0.8 VPS Camera Module
[17 01][00] v2.0.1.6 -> v2.0.1.6 VPS Sonar Module
[19 00][00] v1.0.8.96 -> v1.0.8.96 ++++++++
==== Different between Cameras
++++ Additional with X5
Now if we can ascertain which system each item is, we could understand better which function is which. In my research I have come across the following:
[01 xx] Camera (Camera sensor? Camera MicroSD card interface? Gimbals?)
[11 xx] Battery
[12 xx] ESC
Based on the logfile differences between a FC550 (X5) and a FC350Z (Z3) we have major differences in [04 00] as well as [01 00/01/04], along with [08 00]/[15 00]/[19 00] all being present in the FC500 (X5) but not the FC350Z (Z3). Conversely why is [04 01/02/03] missing in the FC550 (X5) vs the FC350Z (Z3)?
Again, the only difference between the logs is one has the FC350Z (Z3) camera mounted vs the FC550 (X5) camera during the firmware load.
Now, it would seem logical that I would install the X3 and do a downgrade to v01.08.01.00 and finish off the listing here, but that is where I am asking if anyone has a v01.08.01.00 logfile available? (hopefully someone has one saved on thier system somewhere)
If so, if you can post the same block of revision chains like I did I can add the v01.08.01.00 revision to the listing above and we can get a complete view of the modules being changed per rev from v01.08.01.00 up to the latest.
I am of the mind that camera revisions only help the cameras do their job better with "fixes" and "enhancements" since they are not part of the rest of the subsystems, thus I want my cameras to all be running the latest (greatest?) revisions available for them, thus "downgrading" the firmware is not an option for me.
Now, there is a tool out there that allows for breaking down the firmware into individual modules. It is used to change flight parameters. I am wondering if it can also be used to "build" a custom firmware that would include, say, everything from the latest firmware (v01.11.01.50), but with the radio module that allows for the best distance while keeping video intact (ie, v01.08.01.00). NOTE: It is not needed, because if you update to v01.11.01.50 and then use a different camera (Osmo+ FC350Z for example) to downgrade the craft, the camera subsystems do not get downgraded. So ultimately a downgraded aircraft to v1.08/v1.09 with a latest-version camera is the same except for the radio/flight controller, which is all we are worried about.
I think if the module functions can be ascertained as to what subsystem each is responsible for, we can move forward in getting that accomplished.
I am still doing research and believe I came across a reference to the subsystem modules, so I will edit with those clarifications if I can find them again.
[11 xx] Battery
[12 xx] ESC
