DJI Matrice 210 RTK - Wrong Altitude : UPDATE
UPDATE: 03/14/2018
DJI Repair - Accepted/Diagnosed - Brand New Matrice 210 RTK - Issue:
Needs New: Barometer Board & Lower Barometer Cable (Under Warranty)
So if you are having similar issues, send it in for reapair.
The issue is software and hardware related. On the GO4 app, GPS Screen the altitude is just showing numbers but no (M/F) Meters/Feet, Figured out that it is in meters, but showing wrong altitude. I was able to manually change/adjust but it will not update based off of IMU sensor. I have calibrated sensor multiple times to no avail. Rest to factory settings, add updates to everything (correctly).
The DJI Matrice 210 RTK works, I have connection, all green lights, Lat/Long are correct but still same issues as stated above, after multiple phone calls with DJI Tech support, they finally gave me an RMA and I sent drone and base station to them to figure out what is going on.
So as soon as I find out something I will post here. If you have any questions on setup connections let me know, I had orientation and position on the drone and RTK was working. Anyone else having any issues similar to mine please let me know and if you solved it.
ChristiFar
