Dji X5s camera please help
Hi ppl my X5s camera keeps locking on an object how do I stop it doing this . Thanks
In Follow mode, the camera will rotate with the yaw of the aircraft, in free mode, the camera will remain in the same direction when you rotate the aircraft. You can pan the camera in both modes. I normally use "free mode" as I like the camera being in the same direction the aircraft is facing (especially if I'm using the Litchi app)
Were will I find this in the go4 app ? What is this comeing under to change this ? Thanks
I would also like to thank you for the Manual for download I was also having the same problem trying to pan the camera while flying. Thanks for the info
Hi . So yes that will turn it to free and follow . I put in follow and it’s ok for 1 minet then it stays fucus on same place ? Why dose it keep doing that ? Switching by its self
VanitaYaga
