Flight Record on remote control or only on sd card inside cam?
If you did loose your Inspire in the woods somewhere .... can you open up the flight record in the app to help find where it is? Assuming that you didn't lose connection to the drone?
Thanks very much!
The flight tracker record (copy of map and flight) is stored on your tablet device. It can uploaded to the cloud (DJI) and sync'ed with your other devices (if you have one). This will give you a good idea where the last recorded position was.
There are other 3rd party tracker devices are available but most rely on good GSM (cellular/mobile) coverage.
Reactions: Wesmann
RefugioCky
