FLIR XT2
The Zenmuse XT2 FLIR Duel Sensor Imaging Solution
Robust Dual-Sensor Thermal Solution
Housed within a weather resistant encasing is a combination of FLIR's advanced radiometric thermal sensor
and 4K visual sensor - all integrated seamlessly with DJI's powerful enterprise drone platforms.
<50MK - Thermal sensitivity (NEDT)
12MP Visual Sensor
30HZ Max Thermal Frame Rate
IP44 LEVEL Ingress Protection
Transform Data into Insights in Real-Time
Enabled by a suite of processors and computer vision algorithms, the XT2’s onboard
Machine Intelligence helps teams identify what’s important while on-site, instead of after a lengthy processing time.
Temp Alarm
Don’t miss a thing with instant notifications when object temperatures exceed pre-set parameters
Heat Track
Capture the most critical information by automatically locking the XT2 onto the hottest object in view.
FLIR MSX[emoji768]
Quickly interpret data with details from the visual image overlaid on the thermal data stream.
Applications
See the unseen. FLIR thermal sensors reveal details invisible to the naked eye by making subtle differences in temperature visible. This new view on the world can reveal when equipment or buildings are damaged, the location of lost people and much more.
Firefighting
Solar Inspection
HazMat
More
Ready for Action
M200 Series and M600 Pro Compatible
With a quick turn of the wrist the Zenmuse XT2 secures onto DJI’s industry-leading M200 Series and M600 Pro drones to provide pilots a direct view and control of this powerful thermal sensor.
When the XT2 is mounted onto a M200 Series drone, pilots have a combined solution that extends the operation window for drone technology - letting pilots fly confidently in lowlight conditions, through a strong breeze or in light rain.
Utilizing the M210 drone models, pilots can build more robust drone solutions around the XT2 over time by adding zoom cameras, additional onboard computers and other payloads to fit a variety of specialized missions.
Purpose-Built Application
DJI Pilot
Professional Flight Control
DJI Pilot is a robust Android app developed specifically for enterprise-users to unleash the power of their DJI drones. With development made specifically for the XT2, DJI Pilot optimizes your flight and aerial imaging process.
• Access and adjust Spotlight Pro flight modes
• Select area and parameters for Temp Alarm
• On-screen temperature measurements
• Access to color palette, isotherm, and other thermal settings
With a total of 12 models with adjustments in lens size, frame rates and resolution, there is an optimal option for every user. Please contact a DJI Enterprise channel partner to learn which Zenmuse XT2 camera best addresses your needs, more Info can be found at
DJI Zenmuse XT2 - Dual Sensor Thermal Imaging Solution
pricetag?
As we speak, unknown ... But, i assume it is in the same range as the XT - 10k.
Maybe a 320 model, non-radiometric is around 8k, and going up skywards with the other configurations ;-)
Plan on $15k. Hearing through the woodwork, that’s probably going to be the price tag arena. Basically it’s an XT and a 12MP X4S.
Reactions: Advexure
XT2s are arriving in any day for our pre-orders and we should have stock as well. Looking forward to posting up some real life missions and demos in the next week that will be in the firefighting and solar panel inspection verticals. The ability to cleanly integrate RGB, 30X zoom and thermal on the 210 is simply awesome. THREE types of imaging in ONE aircraft that are all fully integrated with one flight operation platform. What’s next?...
I used the XT2 yesterday in a Public Service search of a river, the dual picture function allowed me to fly fairly easily in daylight. The thermal image was quite remarkable even at 150 feet.
Which gimbal does the XT2 fits? (Z30 type or XT type?
