Flying 2 Matrice 100's in close proximity
Hi,
I'm experiencing signal interference when flying 2 Matrice 100's in close proximity. If we turn one controller off the error message goes away. Is there any way around this? It even happens when the other controller is 30m away. Both controllers are in master mode controlling individual Matrice 100's
Many thanks
Hi,
Many thanks
Is the interference on the control or just the video feed?
The FHSS 2.4ghz control data should be fairly immune to interference even in close proximity.
However, the Lightbridge feed can suffer problems with one or two machines close to each other.
In these circumstances it is best to experiment with selecting a channel manually.
There is also a 32 channel hack (non official) which will give you the full 32 channels to choose from.
Ahh, I don't recall the error message saying it was video or control. I have no camera mounted yet. I did notice when one controller was powered off the error disappeared. So am assuming the control signal.
Udaipurescort66
