Golf Course Showcase Video - Appreciate Feedback
Hi Matt,
Nice work A quick question: for your real estate work, what camera, lens, stabilizer are you using for your interior shots?
Thanks.
Jim
For interiors we use multiple setups depending on the scope. For a typical home, I use a cage system with a 3 axis gimbaled GOPRO on it. The GOPRO has been modified to use interchangeable lenses since fisheye is awful. The gimbal is called a Rider. I like it because you can change how it connects to things, instead of it being on a stick/hand mount all the time. The cage has a rechargeable HDMI Liliput monitor on it, and mounts for mics and other things if needed. We have a DJI Ronin as well, and will also use a Blackmagic Cinema 4K EF production camera in RAW or Prores at times or a DSLR. This is by FAR a superior look, but the workflow is greater and the file sizes can get astronomical. Since Real Estate videos need to be quick and easy, we generally go with compressed footage from the modified GOPRO and the Inspire so that I can deliver the end product either same day or next day if needed.
We film everything at 4K 30FPS for the most part, since slow motion isn't usually a part of these videos. If anything, you'll notice I speed up transition shots a lot. This allows me to show more of the home without having to cut, and it's a pretty awesome effect. We actually used to literally take the props off the Inspire and I would walk around the home with it! People always comment that it feels like we flew the drone through the house, and that was kind of what I was going for.
Hope that helps!
Matt
This subject is the very reason I bought my Inspire 1 recently. I would like to comment on a lot (but not all)of the videos we see online. We see many high and wide shots of golf courses that in reality DONT give the visitor/golfer what they want, and that's a perspective of the contours of the holes they will play when visiting the course. As a golfer of some 50 years when I see those high shots I simple switch off as they make a course look flat and uninviting. As for your door opener I am sure it will give you the opportunity you seek. What I plan to do on my first course shoot (which I am lucky as a member already) is to capture the clubs facilities (as you did), a short high panoramic shot and as the final shot a low level flyover of the courses best hole. No more height than the fairway trees from tee to green. No piano music but instead native bird sounds from around the course with some very soft strings.
