Greetings from MS
Hello to all. I am a Phantom, Inspire and Matrice pilot. Pleased to meet you. I hope to deepen my understanding of the Inspire 2 X7 combination through similar experiences. Cheers,
Thanks! I’d like some insight on custom balance rings. Are their any out there? When I stack provided rings and ND fillter, I cant use the lens hood.
What we have found as you have is that you can not stack filters and rings and use the lens hood. You need to use a heavier ring/filter or use alternative methods of balancing the camera/lens combo. We have found that B+W filters are a bit heavier and can balance the lens better than the balance rings. Whether it be an ND or clear uv filter.
Which lens/lenses are you having issues with balancing? Keep in mind that the lens hood is not always needed although I understand your concern about wanting to use it.
I do not have all the data in front of me due to the holiday weekend but should be able to get our info and share it with you on Tuesday.
VanitaYaga
