I1 remote for repair
Update
I have an I1 remote that looks nearly new but is missing 1 rubber nub on bottom and the the small circuit board inside the plastic hood has an issue. It's what the Hdmi cord plugs into. For whatever reason it stops video to the viewing device
Board needs to be repaired or replaced.
Any offers?
Sent from my SM-G920V using Tapatalk
This is the part that is bad
Sorry. Small circuit board that has the USB connection. Swapped boards briefly to verify that was the issue.
I don't understand why the Hdmi port would cause issue with video output using the usb port but when I swapped this board out the controller worked fine. I originally thought it was a bad usb port but when I put the larger circuit board that houses the usb it still did not function.
