I1 X5R FW shows 1.10.1.40 after 1.11.01.50 Update
A bit stumped, have X5R that continues to show 1.10.1.40 in the RC's "About".
App 3.1.30
AC 1.11.01.50
RC 1.7.80
Camera X5R 1.10.1.40
Camera X5 1.11.01.50
A9 Plus 01.15.18.09
Fly Safe DB 01.00.01.07
Even after performing & completing SD Card upgrade forced with including the WM610_FW_DEBUG file.
If not using the debug, it passes the update indicating all software up to date without performing upgrade.
For X5Raw, using WM610_FC550R_FW_V01.11.01.50.BIN
for X5, using WM610_FC550_FW_V01.11.01.50.BIN
After the forced update... D D D D for long time to D... DD complete about 45-50 minutes with all motors getting touched (Red Flashes) and various LED flashes toward the end of update.
In other words, a normal upgrade procedure.
For Reference; I also have a X5 and it upgrades normally and showing 1.11.01.50 matching the AC.
I've performed the lengthy forced upgrade twice with same completing results showing 1.10.1.40
Everything functions normal without issues, I'm assuming the X5R is current with 1.10.1.40.
Odd because the X5R current download indicates 1.11.01.50.
Do I need to force a downgrade to something below and then a forced upgrade?
Or is the display for the X5R correct?
If needing a downgrade.... does anyone have something below 1.10.1.40 FW.
Well, I guess I've found that the version displayed is correct per this X5R release notes for the 1.11.01.50 version. Within the document it indicates the Camera version should indicate 1.10.1.40 when completed and the AC should be 1.11.01.50.
Reactions: Skyward Imaging
