IMU won't calibrate after crash
I crashed my inspire 1 pro and this has come up, it won’t do both when I try to
Calibrate imu, the camera rotate at set up then just hangs funny and says can’t find master remote. But master remote let’s me put it into travel mode and out. Any ideas
Follow this thread with regards to your IMU calibration (check the fan for damage) and check the two ribbon cables that connect to the gimbal mounting point for damage or pin misalignment..
Follow this tutorial you will see a fan when the top is removed..
thanks will take a look tomorrow, where can I get a fan from if I need one? and I see the other guys was ok after fan repair hope this is my problem, thanks for help will let you no.
snaaifer
