Inspire 1 V2.0 Gimbal does not spin on startup
Help. When I turn on the drone the global doesn't spin. It doesn't send video to the app too. Does anyone know what's wrong?
check the small pins and plates on the mounts. should be clean shiny and straight. also any recent hard landing/crashes?[/QUOTE what do you recommend to use to clean the contact points and/or straighten them if need be?
remove the two front rubber dampers as well and check the plugs are fully seated and snapped in place
All checked still no joy. The fan in the camera is on though. It just wing spin up and stabilize
I have deleted your other thread saying basically exactly the same thing!
Please do not double post, it is against our forum rules.
Thank You
Reactions: TixFJ
ChristiFar
