Inspire 2 gimbal control
Hi all
I am physically disabled and can only use a tablet with a mouse. My mate and I are looking at getting an I2 but we were wondering if the gimbal could still be controlled by moving your finger/pointer around the tablets screen as I believe you could with the I1. We are wanting to be a dual operator set up with me doing the camera work.
From what I can see, you can only move the cameras vertical movement with the blue dot on the screen and not horizontally. I could be wrong, for I am a newbie
If it only goes up/down, then switch from follow to free mode, that unlocks the gimbal yaw.
When in free mode, you can pan/tilt the camera by dragging your finger on screen, certainly on a single operator setup. I'd presume you can do the same with a dual op setup too.
Reactions: Ftolino
JessikaTre
